Moin,
noch etwas neues von Olight
Wer sich nicht für die Olight SR50 Intimidator erwärmen kann, könnte auch zur M31 greifen
M31 Triton
Specification
High Mode : 800lm(1H)
Medium Mode : 320lm(3.5H)
Low Mode : 60lm(14H)
Strobe Mode : 10Hz(2H)
Battery: 3xCR123A or 4xCR123A/2xLi -ion 18650 with extended tube
(Note: we don’t suggest using RCR123A batteries since they can not offer enough power under high Ievel)
Dimension: 63mm /2. 48 “(D) X211mm / 8. 31 " (L)
Body Diameter: 25mm / 0.98”
Weight: 266g/ 9. 38oz (Exclude batteries)
Function: Three brightness Ievels and strobe mode
Accessories: Include one battery magazine (required for 3pcs CR123A batteries), one holster, one extended tube, one operator’s manual, two o-rings
Warning: Please use high mode sparingly. Due to its high power consumption, an excessive amount 0f heat may be built up and it may harm the batteries and the flashlight.
Features
World-class super bright Luminus SST-50
Max 800 lumens
Max 14 hours long runtime
Three digitally controlled constant brightness levels and strobe
Rugged indestructible aluminum body with anti-scratching type III hard anodization
Engineered anti-slip knurling for a tightly firm grip
Tactical forward switch for power on/off and easy momentary-on
Dentate bezel head and tail provided for close quarter combat
Multi-scattering slot design to protect LED and electronic components
Built-in stainless steel pocket
Highly water resistant to IPX-8
Smooth reflector offers max 700m long throw
Anti-shattering ultra clear lens, anti-scratching and anti-slip
Friendly user interface, rotate the head for transferring mode.
Operated by 2x18650 with extra extended tube to prolong the runtime
Removable stainless steel clip
Mountable on weapons with compatible weapon mount
Operation
Turn On/Off the Power
Pressing the tail cap switch will turn on/off the power
For momentary light, gently press (no click) the tail cap pushbutton switch.
For constant light, fully press (click) the tail cap pushbutton switch.
To switch functions, click on the light, loosen the head(see figure 4) by 1/8 of a circle and then tighten it down, the light will move to the next function. Repeat the same operation for further functions.
Lockout Mode: To lock out the switch, rotate the tail cap approximately 180°counter-clockwise. The lock out position prevents accidental activation during storage or transport.
Quelle : Olight M31 Triton
Pre-Order : 4sevens.com : *Pre-Order, Ships 08/24* Olight M31 Triton
Klondike
M31 Triton
Specification
Features
Max 800 lumens
Operation
Klondike
