Moin,
soeben auf der Seite von ITP über dieses Exemplar gestolpert. Die Form finde ich durchaus nicht gewöhnlich.
Hier stelle ich Euch schon mal die technischen Daten ein:
Battery installation:
Remove the light tail.
Insert the battery with the negative end toward the tail.
Operation:
Insert the battery and tighten the tail
Tighten the head clockwise to turn on the headlamp.
When the light is on, loosen (counter-clockwise) and tighten (clockwise) the head within 1 second will change the mode
from low, medium to high level.
When choose a specific mode, the headlamp with memorize it and next time the headlamp will enter into that specific
mode when turning on.
Loosen the head to turn off the headlamp.
Warning:
If you don't need to use the headlamp for quite a long time, it is suggested to loosen the tail as well,
which will avoid the unexpected turning on.
Quellennachweis: H01---ITP light electronic Co., Ltd
Klondike
- LED Type: Cree XP-E Q5
- Function: Low-Med-High
- Finish: HA Type Ⅲ
- Reflector: Orange Reflector
- Lens:Anti-shattering ultra clear lens, anti-scratching and anti-slip
- Water and Dust Resistant to IP68
- Switch: Head Twisty Switch
- Mil-spec: MIL-STD-810F
- Battery: 1 x AAA, 1 x Rechargeable NiMh AAA, or 1 x 10440 (due to the small body size, 10440 batteries are
not recommended since it may cause the light becoming hot very quickly). - Functions and Runtime
Three output levels: Low 1.5 lumens (50 hours) -> Medium 18 lumens (4 hours) ->-High 80 lumens (55 minutes) - Standard Accessories: 1 x Clip, 2 x O-rings, 1 x Manual
- Size and Weight:
L 52.5mm (2.07'') x D 16.2mm (0.64'') x W 36.2mm (1.43'') ,
22.8g (Excluding Battery and belt), 50.8g (Excluding battery)
Operation:
Warning:
Klondike
