Specifications:
Emitter: Nichia 219B
Battery: 1*AAA or 2*AAA (compatible with rechargeable and alkaline AAA battery)
Working voltage: 0.9-4.2 volts
Maximum Output: 200 lumens
Output&Runtime:
Moonlight: 0.5 lumen, 100 hours
Medium: 17 lumens, 13.5hours
High: 200 lumens, 35 min
Maximum Beam Intensity: 880 CD
Maximum Beam Distance: 60 Meters
Driver: Most efficiency constant current driver with a long runtime up to 100 hours
Body Material: Aluminum alloy
Clip: Stainless steel clip
Lens: Double coated anti-reflective coating lens
Reflector: OP reflector
Waterproof: IPX-6(1.5 meter under water)
Impact resistance: 2 meters
Dimensions:
Length: 128.5 mm Diameter: 16.6 mm Weight: 30g (without battery)
Accessories: Stainless clip*1, Spare O-ring*2
Operation:
There is a stainless clicky switch on the tailcap.
Two kinds of pressing methods:
1. Half press: half press for momentary on, continue half press(within 10 seconds) to modes circle: Moonlight-Medium-High-Moonlight-Medium-High-Strobe-Moonlight......(Over 10 seconds the light will turn on in moonlight)
2. Single click: single click for constant on, continue single click(within 10 seconds) to modes circle: Moonlight-Medium-High-Moonlight-Medium-High-Strobe-Moonlight......(Over 10 seconds the light will turn on in moonlight)
