Manker Flood Flashlight 12 Emitters 8000 Lumens Runs of 3 18650 Batteries
Key Features:
1. 12 Emitters (3 quad MCPCBs)
2. Max output 8000lumens with Cree XP-G3 emitter,6500 luemns with Nichia 219B emitter
3. Working voltage: 2.8V-4.35V (Over discharge protection)
4. Reverse polarity protection and battery indicator
5. Most efficiency constant current circuit driver
Specifications:
1.Emitter: 12 Cree XP-G3 / 12 Nichia 219B (two version for your choice)
2.Maximum output:
Cree XP-G3 8000 lumens
Nichia 219B 6500 Lumens
3.Maximum beam intensity:
Cree XP-G3 20000CD, maximum beam distance 280 meters.
4.Working voltage: 2.8V-4.35V (Over discharge protection)
5.Driver: Most efficiency constant current circuit
6. Material: Aircraft-grade aluminum body
7. Surface treatment: Premium Type III hard-anodized anti-abrasive finish
8. Lens: Toughened ultra-clear glass lens with anti-reflective coating and TIR
9. Water proof: IPX-8 (2 meter under water)
10. Impact resistance: 1.5 meters
11. Tail stand
Dimensions:
Length 98mm, Diameter 55mm
Weight 278g (Without battery)
Accessories: O-ring *1, Lanyard*1, User manual*1
Output and runtime:
Moonlight: 0.1-30lumens /2months-5days, Low: 120lumes 30hours
Medium 1: 500lumens 7.5hours , Medium 2: 1000lumens 3.5hours
High: 2500lumens 2hours , Turbo: 8000lumens, Strobe: 8000lumens
Batteries: High drain unprotected 18650 batteries are recommended.
(The package does not include any battery)
Side switch battery indicator:
1. Blue: More than 75% 2. Purple: 50% 3. Red: Less than 20%
Lock out:
One click-Double-Triple from any mode to lock out the flashlight.(Only the battery indicator works when lock out)
Engineering Mode(Choose output level for Moonlight mode): Long press for off and still hold on, the side button battery indicator will turn on and then quick click for 4 times to get access to engineering mode. One click to check different level and long press to make your final choice.
For more details please refer to: Manker MK34
Key Features:
Specifications:
2.Maximum output:
11. Tail stand
Dimensions:
Output and runtime:
Lock out:
