Acebeam K40L max 1560 lumens flashlight
ACEBEAM
Hersteller
27 März 2013
293
654
New model K40L has been released.:D K40L CREE XPL 1560LM Throw 760M
http://acebeam.com/Content/Images/uploaded/K40l/K40L-01.jpg
http://acebeam.com/Content/Images/uploaded/K40l/K40L-02.jpg
http://acebeam.com/Content/Images/uploaded/K40l/K40L-03.jpg
http://acebeam.com/Content/Images/uploaded/K40l/K40L05.jpg
http://acebeam.com/Content/Images/uploaded/K40l/K40L-04.jpg
http://acebeam.com/Content/Images/uploaded/K40l/K40L-06.jpg
http://acebeam.com/Content/Images/uploaded/K40l/K40L-07.jpg
Features:
Cree XPL LEDs with lifespan 20yrs of runtimes
Max 1560 lumens output (3x 18650)
Output (select by magnetic ring):
Level 1 : 0.5lm(2000hrs)
Level 2 : 25lm(140hrs)
Level 3 : 230lm(20hrs)
Level 4 : 550lm(5.5hrs)
Level 5 : 950lm(2.8hrs)
Level 6 : 1560lm(1.5hrs)
Standby : 65uA
Strobe : 1560lm (4hrs)
Working voltage 4v - 13v
Max Runtime 2000hrs
Max beam 760meters
Peak beam intensity 144300cd
Aircraft grade aluminum body structure
Premium Type III hard anodized anti-abrasive finish
Ultra-clear tempered glass lens with anti-reflective coating
Momentary forward click tactical switch
Strobe mode for tactical and emergency use
Smooth reflector for max light output
Highly focus beam for maximum distance
Tactical knurling for firm grip
Streamlined body design
Mechanical reversed polarity protected design
Intelligent high efficient circuit for max performance and runtime
Intelligent temperature controlled light output for safety
Impact resistant 1.2meters
Waterproof : IPX-8 Standard (2meters)
Size 186mm(length) x 76.2mm(head diameter)*49mm(tube diameter)
Weight 453g
Cheers!
Acebeam Team
AceBeam®
Rafunzel
10 Oktober 2010
9.327
5.347
Hamm, NRW
Hi Acebeam Team,
thanks a lot for the K40L news. Can you also tell some further news (and pics) about the H10?
Best regards,
Rafunzel
12.438
Any kind of battery warning?
Working voltage down to 4V means protected batteries are mandatory.
The LED on your photo K40L05 is not a CREE XP-L, but apparently XM-L2. Wrong photo?
1560lm output (OTF, ANSI?)
The highest XP-L bin V5 emits 1034lm driven at 3A (rated max) at 85°C.
Are you overdriving it with 5A (about 18W) :D? This would match with runtime 1.5h on max.
MetalDeep
4 November 2010
2.444
695
Weißwasser
Die ACEBeam K40 mit Cree XM-L2 LED wird mit 1368lm und 816m Reichweite beworben diese K40L hat zwar 1560 Lumen durch die XP-L LED aber dafür wiederum "nur" 760m Reichweite was ist da nun der Fortschritt ?
G
Gelöschtes Mitglied 10832
Wenn der CD Wert von ca. 144000 wirklich stimmt :D
dann scheinen die anderes gerechnet zu haben. Die XM-L2 Variante hatte, wenn ich das noch richtig im Kopf habe, einen Wert von um die 90 000CD.
urausb
18 September 2011
2.992
1.782
Kr. AB
Ich habe schon die K40M und suche die ganze Zeit ein einziges Argument, das für die K40L spricht. Vielleicht findet ja noch jemand eines?
G
Wie gesagt, wenn der CD Wert von 144 000 stimmt, dann ist die K40L ein guter Thrower. Auf jeden Fall kommt sie um einiges weiter als die K40M und blendet im Nahbereich vermutlich dann auch nicht so stark wie die K40M, wenn man in die Ferne leuchten und schauen möchte.
ps. reicht das :confused::D
Reaktionen: urausb
mkr
2 Februar 2013
10.898
15.132
Nanda Parbat
Zweitlampe. :D
Ja, und ich möchte wissen was an der K40L (XP-L) besser ist im vergleich zur K40 (XM-L oder 2er Version) ;)
Ich nehme mal an, das wird der Nachfolger sein, und die K40 wird's dann bald nicht mehr geben (sobald die Restbestände abverkauft sind).
Ich bin allerdings durch persönliche Erfahrungen von XP-L statt XM-L2 eher enttäuscht, von der Lichtfarbe her (Erfahrung aus EagTac, Klarus, Thrunite- Lampen). Bei XM-L2 scheint's mir im Moment noch die schöneren Farbbins zu geben.
Viele Grüße,
Markus
Reaktionen: urausb
Max2013
22 September 2013
392
85
Also als Thrower.... Warum keine Alternative zur T32?
Das wäre mal nett.
Sonnen
21 Dezember 2012
2.404
1.338
Österreich
:confused:Ich kann mir nicht vorstellen das nur wegen XP-L der Candela Wert so steigen soll warscheinlich ist der ziemlich der selbe, nur etwas höher.
