Sorry to say, I do not speak German. I saw the
pictures kj75 posted at CandlePowerForums, so I thought you might like to read my impressions.
My
Sunwayman T25C arrived yesterday. It is a 1x18650, compact zoomie. It uses a 38mm convex lens in conjunction with a reflector, so the focused beam is pretty good. Flood is excellent.
The UI is a little funky. The T25C has a forward-clicky, tail-cap switch, so you have to set the mode using half-presses, before you click to lock it in. Here is how it works.
Start with the T25C powered off. All of the half-presses below end with the flashlight on. If you release the switch, the flashlight powers off, and you have to start over.
- A long half-press powers on in the mode stored in mode memory. Be sure to hold long enough to establish that the flashlight is powered on.
- Next, a quick double-half press activates strobe mode.
- Otherwise, use a series of slightly longer half-presses to cycle through constant modes. The sequence is Low, Mid, High, and Turbo.
- When you see the mode you want, click all the way to lock it in.
Note that this is different from what the documentation describes.
Overall, my first impression is good. I may have found my new favorite indoor flashlight. I tend to prefer the flood mode of a zoomie indoors more than the hot spot and spill of a flashlight that has a reflector.
Neutral tint and higher CRI would make this even better.
I won this flashlight in a Sunwayman giveaway. Thank you, Sunwayman!
GOOGLE TRANSLATE
zu sagen, Sorry, spreche ich kein Deutsch. Ich sah die Bilder kj75 bei CandlePowerForums geschrieben, also dachte ich Dich meine Eindrücke zu lesen.
Mein Sunwayman T25C ist gestern angekommen. Es ist ein 1x18650, kompakt zoomie. Es verwendet eine 38mm konvexe Linse in Verbindung mit einem Reflektor, so der fokussierte Strahl ist ziemlich gut. Flood ist ausgezeichnet.
Die Benutzeroberfläche ist etwas abgefahren. Die T25C hat eine zukunfts clicky, Endstückkappe Schalter, so dass Sie den Modus mit Halb drückt setzen müssen, bevor Sie sie in zu sperren klicken. Hier ist, wie es funktioniert.
Beginnen Sie mit dem T25C ausgeschaltet. Alle der Halb drückt unten Ende mit der Taschenlampe auf. Wenn lassen Sie den Schalter, um die Taschenlampe ausgeschaltet wird, und Sie müssen von vorne beginnen.
Eine lange Halb drücken schaltet sich im Modus im Modus gespeichert. Achten Sie darauf, lange genug zu halten, um festzustellen, dass die Taschenlampe eingeschaltet ist.
Als nächstes aktiviert eine schnelle Doppel Hälfte drücken Strobe-Modus.
Ansonsten eine Reihe von etwas längere Halb drückt, um durch konstante Modi verwenden. Die Reihenfolge ist Low, Mid, High und Turbo.
Wenn Sie den gewünschten Modus zu sehen, klicken Sie auf den ganzen Weg, es zu sperren in.
Beachten Sie, dass dies unterscheidet sich von dem, was die Dokumentation beschreibt.
Insgesamt ist mein erster Eindruck gut. Ich mag mein neues Lieblings Indoor-Taschenlampe gefunden. Ich neige dazu, die Flut Modus eines zoomie drinnen mehr als der Hot-Spot und das Auslaufen von einer Taschenlampe zu bevorzugen, die einen Reflektor hat.
Neutrale Tönung und höher CRI würde diese noch besser zu machen.
Ich gewann diese Taschenlampe in einem Sunwayman Werbegeschenk. Vielen Dank, Sunwayman!
