[MODs] TN42lx und GTlx mit CFT-90, erste Tests und Zusammenbau
Dieses Thema im Forum "Lexels Treiber und Projekte" wurde erstellt von Lexel, 22. April 2018.
  1. I started this idea a while back pretty much same as Skylumen
    I put it not on high priority and a lot of time passed without any progress
    I have now tested the first driver thats function works as expected, still its a prototype which has a too high standby drain,
    I need to get someone implement a Enable output in NarsilM to be on while MCU is awake and off when in sleep
    as it is now the buck chip and temperature sensor reference voltage east a few mA which is not acceptable for me
    So lets look at the driver design for the prototypes
    GigaThrower
    TN42
    LED mounting the GT is easier than in the Tn42 as I can open the head close to the LED
    first get those connectors off them, not easy as the LED- is as well the copper core
    So I decided to destroy the plastic part and use a 30000°C gas burner to get it desoldered which worked
    Unsoldered
    Integrating in the GT
    marks for drilling holes and make M2.5 threads
    M2.5 screws fit nice, my M3 are too high
    Also drilled two 6mm holes for wires
    The centering bar in palce it was sanded about 0.7mm to get the LED in the focal plane
    I need to glue later the scres from it as they are not fixed
    soldered two times 2×1.5mm² silicone wire, squeezed it flat and insulated with kapton tape, even if it is not as high as the centering bar
    The centering bar needed to be trimmed a bit
    head parts screwed to one piece
    I put the LED on a 5A bench PSU for a quick beam shot, the focal point might not be ideal
    This is the 6500K variant vs 4000K GT XHP35
    Now to the TN42
    Putting the centering piece on the LED
    now marked its outer diameter on the LED board with a knive
    Sanded the piece like the GT centering bar, and cut out the LED and temperature sensor
    having a quick look on the reflector I am not sure if the gap to the LED wires will be enough not to make a short
    Also the head needs electrical insulated from the carriers ground
    So I made the holes bigger and will use Kapton tape around the screws and a plasic washer to insulate them
    centering piece glued to the LED
    Soldered 2.25mm² wires to the MCPCB and mounted it in the head
    I made a Mistake and drilled 2.5 instead 2.1mm for M2.5, so I had to use nuts, but it works
    I used my Dremel to got some material on the reflector removed, where the LED wires are and insulated it,
    but it seems the reflector can rotate in the head not touching the LED wires, so for safety I will make this all around the reflector base
    [​IMG][​IMG]
    first test with my prototype driver
    Erster test bei 23A ergibt 710kcd, vermutlich passt der Fokus noch nicht
    #1 Lexel, 22. April 2018
    Lampi-on, tomtetom, cloudbounce und 13 andere Flashys haben sich hierfür bedankt.
  2. Folomov
    Sieht gut aus man!
    Die Zentrierung sieht bei die TN42 gut aus, aber wie Du sagst ist die Fokussierung vielleicht noch nicht 100%.
    Der Spot sieht aber schon echt gut aus!
    Ich denke, bei die GT hast Du noch was zu tun.
    LG
    Nico
  3. Bitte weiter berichten .. :thumbsup:
    alexp hat sich hierfür bedankt.
    Schaut schonmal ziemlich geil aus :D fehlt noch der letzte ''Feinschliff'' hehe :thumbsup: :cool:
    Xandre hat sich hierfür bedankt.
  5. Vinh hat heute berichtet, dass seine finale TN42vn90 auf über 5000 Lumen und 1-1.1Mcd kommt. Keine Ahnung wie er das mit seinem Treiber macht. Er meinte ja der Treiber macht nur 20A maximal.
    Hefty hat sich hierfür bedankt.
  6. Hier noch ein Hinweis, mit dem du das nächste mal ggf. die Reflektoren heil lassen kannst:
    Stone Modding Tipps - Ultra flache Lötstellen
    Das ganze war vor deiner Zeit hier im Forum, daher kennst du es vermutlich noch nicht.
  7. Skilhunt Taschenlampen
    Respekt:thumbsup:
  8. Das hängt vom genauen Farbbin ab, nicht von der CCT (bei Luminus meist die letzten Ziffern des Produktcodes, siehe Datenblatt). Auf sowas achtet Vinh wahrscheinlich gar nicht.
