Mecarmy new releasing angle light: Dual Switch (Teeterboard switch) USB Rechargeable Compact light
mecarmyflashlight
Hersteller
24 November 2017
25
Nice to see you again! Let's see our new releasing before Christmas: FM16(shorter) & FM18(longer)
Dual Switch (Teeterboard switch) USB Rechargeable Compact Flashlight
· Dual switch Compact flashlight with USB rechargeable function
· Uses CREE XPL-Hi V3 LED, lifespan up to 50,000 hours
· Momentary ON function
· Instant access to Turbo/ Strobe
· Quick charge in just 90 minutes
· Standard Micro USB Charging port, charges on any USB port
· Charging and fully charged indicators
· Magnetic tailcap provides versatile hands free operation
· Detachable clip
· Over-heat protection to avoid high-temperature of the surface
· Rugged pineapple texture for grip and anti-roll
· Constructed from aero grade HAIII hard-anodized aluminum alloy
· IPX-8 water resistance
LED: CREE XPL-Hi V3 LED
Dimensions:
FM16: Length 99.2mm x Head 29.2mmx Body 23.3mm
Length 3.905" x Head 1.149"x Body 0.917"
FM18: Length 133.2mm x Head 29.2mm x Body 23.3mm
Length 5.244" x Head 1.149"x Body 0.917"
Charging: Micro USB rechargeable, with red/green charging indicators
Accessories:
FM16: User manual, 1*16340 Battery, O-ring, lanyard, USB cable
FM18: User manual, 1*18650 Battery, O-ring, lanyard, USB cable
Notes: The 18350 battery here we mean traction battary like IMR, INR. Which will have higher output than normal 18650
Our international dealers will receive all new items around 15th-20th December.
mecarmyflashlight
Hersteller
24 November 2017
25
Can you give some more information about operating the flashlights?
What about the prices?
I added a picture to the article
Operation
· From OFF: Lightly depress switch A to activate momentary-ON
· From OFF: Fully depress switch A for constant-ON
· From ON: Fully depress switch A for OFF
· From ON: Short press switch B (>1 seconds) to cycle through MODES. (High/Med/ Low)
· From ANY mode: Fully depress switch B (>2 seconds) to activate STROBE.
Press the switch again to turn STROBE off
mecarmyflashlight
Hersteller
24 November 2017
25
It's a little bit heavy if used as headlamp. so it is not supposed to be like that. Yes i put both specification for FM16 and FM18
mecarmyflashlight
Hersteller
24 November 2017
25
[QUOTE = "Riesbachtaler Urgestein, post: 855899, member: 5837"] Also interesting as a head lamp, it would be nice if Mc.Army would offer the dishes. Do the performance values in the table for both lamps?
Is it possible to use the Lamps as Headlamps.[/QUOTE]
Hallo Mec Army has the FM 16 the same Peak Distance as the FM 18?
Hello, they have very silimar beam distance
Lexel
12 Dezember 2016
1.255
1.200
Halle (Saale)
and what if people put in INR or IMR 10/20A PCB batteries like Klarus or unprotected?
It makes no sense a 18650 should perform almost 20% below a 18350.
QUEEQUEG
30 Oktober 2013
78
66
Tolle Lampen, allerdings ist die FM 16 so groß, da bringen andere Hersteller einen 18650 unter.
