Acebeam K60 (XH-P70 LED, 5000lm/124kcd), Photos, Impressions
gopajti
12 April 2014
200
1.226
Ungarn
elemlampa.blog.hu
Hello guys, I would like to show the Acebeam brightest (5000lm) single led flashlight, K60 with new, powerful Cree XH-P70 LED.
Features (from official site),
  • LED: Cree XH-P70 LED with a lifespan of 10+years of run time
  • Max 5000 lumens output
  • Output (select by magnetic ring):
Level 1: 1lm (1300h)
Level 2: 50lm (60h)
Level 3: 700lm (8h)
Level 4: 1700lm (3h)
Level 5: 3400lm (1h30m)
Level 6: 5000lm (1h)
Standby: 65uA
Strobe: 5000lm (3h)
  • Working voltage: 4V - 17V
  • Max Runtime: 1300 hours
  • Max beam distance: 704 meters
  • Peak beam intensity: 124,100cd
  • Impact resistant: 1.2 meters
  • Waterproof : IPX-8 Standard (2 meters)
  • Size: 206mm (length) x 88mm (head diameter) x 50mm (tube diameter)
  • Weight: 570g (without batteries)
  • Aircraft grade aluminum body structure
  • Premium type III hard anodized anti-abrasive finish.
  • Ultra-clear tempered glass lens with anti-reflective coating with 98.3% light transmittance.
  • Momentary forward click tactical switch.
  • Strobe mode for tactical and emergency use.
  • Highly-polished light orange peel reflector for both smoothing out the beam and max. beam distance.
  • Tactical knurling for firm grip
  • Streamlined body design
  • Mechanical reversed polarity protection design for battery carrier
  • Intelligent highly effcient circuit board design for max performance and long run time
  • Specially designed for military, Law Enforcement, Self-defense, Hunting, Search&Rescue and outdoor activities.
  • Intelligent temperature controlled light output for user safety
  • Accessories include: user manual, lanyard, holster, replacement O-ring (1x) and tailcap rubber switch cover
My impressions
Pros
+ Excellent machining and high build quality, nice details, grip surface etc
+ Perfect, scratch-free anodizing, very nice semi matte surface
+ K60 available in four colors: Olive green, Sand Tan, Grey and Black
+ High quality OP reflector for perfect smooth beam with AR coated glass lens
+ Perfectly centered LED (guaranteed in every K60)
+ Ultra high performance only from one LED which is brighter, than many other MT-G2, MK-R or 3/4*XM-L2 flashlights
+ Very nice white tint (incl. hotspot, corona, spill, in all modes)
++ NO PWM or other irritating flickering, all modes looks perfect
++ NO buzzing sounds
+ Easy one hand operation
+ Users can use longer protected cells or standard size 18650 unprotected/flat top batteries without any problem
+ Precise magnetic ring (close to perfect) much more precise than my Thrunite TN35 ring
+ Good looking SS bezel
+ Good quality holster (not full size holster)
+ Tail stand capable
+ Very good price/value ratio
Cons
- No real cons for me, but I would like to see a small battery indicator led (similar solution as on Acebeam X60/X60M)
Other comments
I'm really impressed! The XH-P70 LED performance, beam type, tint, the K60 build quality, battery configuration (4*18650) etc. Overall, close to perfect for me.
I recommend (chargers, batteries):
Chargers: XTAR VC4 (need a wall adaptor), VP4 or 2*VP1/VP2.
Unprotected high drain batteries for maximum performance (for advanced users only): Sony Konion US18650VTC5 2600mAh, Samsung INR18650-25R, LG ICR18650 HE2.
Protected or other IMR cells: Keeppower's black IMR cells, Acebeam own batteries or other VTC5, 25R, HE2 or similar high drain cell based batteries.
For longer runtime: LG INR18650 MJ1 3500mAh, Samsung INR18650-35E 3500mAh, Keeppower 3400/3500mAh cells etc.
Attention! Many fake Sony VTC5 batteries available on market, so I highly recommend, pls check dealers, before buy this battery. I recommend (especially for european members) AkkuTeile.de which is reliable source, if need original VTC5 cells or other batteries.
And now pls check my photos, beamshots etc, more photos coming soon. If need higher res, pls click the photos
gopajti
12 April 2014
200
1.226
Ungarn
elemlampa.blog.hu
GIF Animations
K60 vs Fenix TK35 L2
K60 vs Thrunite TN35
K60 vs Acebeam T25
K60 vs Fenix RC40
GIF Animations
K60 vs Sunwayman D40C
K60 vs Imalent DDT40
K60 vs Microfire L500R V3 CW
K60 vs Foursevens Maelstrom MMU-X3
K60 vs Supbeam (Acebeam) X60 first. gen, 5000lm/~160,000lux (measured by selfbuilt)
GIF Animations
K60 vs Fenix LD50
K60 vs Nitecore TM06
K60 vs Olight SR96
K60 vs Supbeam X60
(K60 worked with brand new and freshly charged, original, unprotected Sony Konion US18650VTC5 cells)
12.438
Very nice photos, great beamshot comparison (as usual :)).
The K60 is well regulated in all modes. Battery voltage even with empty batteries is still almost twice the LED forward voltage. So there is enough headroom for perfect regulation even on turbo and with empty batteries.
The driver draws around 4A from the batteries in the highest mode.
That is, the mentioned low-capacity high-drain batteries will only shorten runtime, but not increase brightness (performance).
IMO a better choice are 3000mAh medium drain batteries like Samsung 30Q, LG HG2.
Even the new 3.5Ah cells are rated for 10A continuous discharge (though they should be kept below 7A).
I would like to verify this, but I'm still waiting for the replacement driver for my own K60. Then I can compare Samsung 30Q (3.0Ah 15A) with 35E (3.5Ah 10A) - and maybe protected NCR18650BF (Soshine) though I expect the latter to become rather hot on continuous high, and give earlier battery warning.
Reaktionen: mkr
mkr
2 Februar 2013
10.898
15.132
Nanda Parbat
I just finished some runtime tests:
Battery Type:1st low batt warning after:output drops below 10% of initial output after:
Sony Konion VTC5 unprotected, 2600mAh37 min40 min
Keeppower protected, 3400mAh34 min50 min
EagTac protected, new 3500mAh37 min51 min
With the new protected 3500mAh batteries, there's absolutely no need or no advantage of using unprotected cells like the VTC5 or the LG HE2 in the K60.
With protected batteries inserted, the K60 just shuts off after the runtime. The batteries are driven into their protection.
(I also have a bunch of LG HG2, but I haven't tested them in the K60 yet.)
- Markus
- Markus
Hallo Markus, sind die EagTac 3500mAh baugleich mit den Keeppower 3500mAh?
Ernst-Dieter
mkr
2 Februar 2013
10.898
15.132
Nanda Parbat
Nein, sind sie nicht.
Die EagTacs sind schlanker und kürzer. Die Keeppower passen nicht in jede Lampe.
Die Keeppower funktionieren z.B. nicht in einer Meteor M43. Die EagTac schon.
31994
Reaktionen: Curetia
Curetia
18 April 2015
766
234
@mkr
Hast du zufällig auch noch welche von dem Olight 3600er da um die mit den EagTac und den Keeppower zu vergleichen?
Mich würde der Größenunterschied der 3 Akkus interessieren, aber meine Olights werden frühestens in 3 Wochen bei mir ankommen, danach kann ich sie mal mit einem Messschieber messen, aber Fotos kann ich leider keine so guten machen, denn ich hab nur ein Smartphone.
