Manker MK35 Cree XHP35 HI 4*18650 2550lumens 1420meters Super Thrower is Releasing
Key Features:
Specifications:
1.Emitter: Cree XHP35 HI (CW and NW for your choices)
2.Maximum output: 2550lumens for CW version (NW version output is about 20% less than CW)
3.Maximum beam intensity: 504100 CD Maximum beam distance: 1420 meters
4.Working voltage: 11.2V-16.8V (Over discharge protection)
5.Driver: Most efficiency constant current circuit
6. Material: Aircraft-grade aluminum body
7. Surface treatment: Premium Type III hard-anodized anti-abrasive finish
8. Lens: Toughened ultra-clear glass lens with anti-reflective coating
9. Water proof: IPX-8 (2 meters under water)
10. Impact resistance: 1.5 meters
11. Tail stand
Dimensions:
Length 188mm, Head Diameter 86mm
Weight 675g (Without battery)
Accessories: O-ring *1, Lanyard*1, User manual*1 Holster*1
Output and runtime:
Moonlight: 0.1-5lumens 1500hours, Low: 47lumes 76hours
Medium 1: 136lumens 21hours , Medium 2: 700lumens 7hours, High: 1600lumens 2.5hours , Turbo: 2550lumens(2550lumens last on 15 minutes then stepdown to 1600lumens) 2.5hours, Strobe: 2550lumens
Batteries: MK35 use 4 18650 batteries
Side switch battery indicator:
1. Blue: More than 75%
2. Purple: 50%
3. Red: Less than 20%
Operation:
Please refer to the image:
Lock out:
One click-Double-Triple from any mode to lock out the flashlight.(Only the battery indicator works when lock out)
Engineering Mode(Choose output level for Moonlight mode):
Long press for off and still hold on, the side button battery indicator will turn on and then quick click for 4 times to get access to engineering mode. One click to check different level and long press to make your final choice.
More details please visit http://www.mankerlight.com/manker-mk...ed-flashlight/
Key Features:
- Cree XHP35 High Intensity LED Max Output 2550lumens, Max Beam Distance 1420 meters with 4 18650 batteries.
- Classical Manker interface gives different output levels and functions and a lock out function help to avoiding accidental turned on.
- Updated Manker side swtich button, solid and more beautiful, retained Manker classical dragon breath function
- Robust body with a stainless steel bezel make MK35 can be used for security popurse
- An ideal flashlight for search&rescue, hunting and law-enforcement etc.
Specifications:
11. Tail stand
Dimensions:
Output and runtime:
2. Purple: 50%
Operation:
Lock out:
